ojobson
Message 1 of 2
SMart Hub - Mu-Mimo now enabled?
Hi,
I read that the Smart Hub, when launched, had MU-MIMO tech in it but at that point it was not turned on.
Has it now been enabled?
It's been nearly two years since launch so if not then I'm guessing it never will be. And in which case I will probably look to replace it with something else. The Mikrotik Hex routers have had some very good write ups for a fairly good price, and so will probably get a WAP to plugin to that...
Cheers,
___________________________________
My Blog: oliverjobson.co.uk | My FTTP install experience | Why can't I order Fibre broadband?
1 REPLY 1
imjolly
Message 2 of 2
Re: SMart Hub - Mu-Mimo now enabled?
it's not enabled
