Xtrato
Message 1 of 2
SSH connection through the Homehub
I'm unsure if this is the correct thread. Sorry if it isn't.
Basically I'm trying to turn off the BTHOMEHUB2's SSH server its hosting. I have an SSH server running on my home network which is facing the internet. At the moment it is setup to use a non standard port and I use port forwarding on the home hub to make it all work. The problem is I need to use port 22 and it is already being used. I cannot see what possible reason there is to have port 22 filtered on the home hub.
 Is there a way to turn this off so it can be used by my SSH server instead?
The only reason I'm curious if this can be done is because the BTHOMEHUB gives me the option to port forward SSH from port 22 as a preset application in the port forwarding options. So it must expect I can use port 22.
Thank you in advance for your help
James
Tags (1)
1 REPLY 1
minusdot
Recognised Expert
Message 2 of 2
Re: SSH connection through the Homehub
Just as an alternative idea, it might be easier (and indeed partially more secure) if you were to change the port that your SSH server is using and have the hub port forward that port instead.
