Message 1 of 6
SSID changing by itself!
Hi, my BT Smart Hub has changed it's SSID for some reason all by itself. I connected my smart new wifi enabled (we now get a notification on our mobiles when the washing is finished - fab!) Bosch washing machine using WPS and now the SSID has changed from the default BTHub SSID to Broadcom_5.
Any ideas?
John
5 REPLIES 5
Message 2 of 6
Re: SSID changing by itself!
Which smart hub is it, as there are now two of them?
Message 3 of 6
It says it's a Smart Hub Type A
Message 4 of 6
Not the new smart hub 2 then?
All I can suggest to do is the following.
Try a factory reset of the home hub.
http://bt.custhelp.com/app/answers/detail/a_id/11386/%7E/how-do-i-reset-my-bt-hub-to-its-factory-set...
Then turn Smart Setup off.
http://bt.custhelp.com/app/answers/detail/a_id/44328/~/switching-smart-setup-on-and-off-on-the-bt-ho...
Also try separating and renaming the SSIDs.
http://bt.custhelp.com/app/answers/detail/a_id/44798/related/1
Message 5 of 6
Mine has just done the SAME thing going to Broadcom_0422671 for NO reason whatsoever.
Changed it back to what it says on the hub settings pull out card/plastic and it shows BTHub6-bla bla bla on the settings page after saving., but all the wireless devices in the house show Broadcom_0422671, ok it's changed again but this time to Broadcom_8627436.
Ok another update turns out if I press the WPS button it changes my SID to Broadcom_(random number)
Newbie
Message 6 of 6
Did anyone find a fix for this please as mine is doing the same. Every time i try and add a WPS device  pressing the WPS button on the router or in the admin interface causes the  SSID to change to Broadcom_xxxxxxxx and all over divices to disconnect. I can change it back but but then the new device won't connect.
