Message 11 of 24
Re: Samsung TV keeps losing connection
@gg30340 wrote:
You can say Amazon, Argos, ebay or any other retailer. It is just links to them that you can not post on the forum..
Did not want to appear to be promoting one shop over another, they all have their good and bad points Smiley Wink
icclebug
Message 12 of 24
Typically rooms not next to each other. Seen refurbed for £44 but be better if I can return if they don’t do the job.
Message 13 of 24
So you only want to promote companies whose name starts with an A Smiley Very Happy
 "I have seen them priced at £44.99 just now, at a shop beginning with A."
Message 14 of 24
You would not be able to use them if you have existing powerline adapters. Did you use those on the Panasonic TV issue in May?
icclebug
Message 15 of 24
No Keith, I managed to use a wired connection, all been good since.
Can you use them plugged into extension cables?
Message 16 of 24
Maplin are doing the BTWifi Homehotspot 500 triple kit for £35.
EDIT: It looks like they might be out of stock on line but your local shop may still have them.
Message 17 of 24
If they are just the normal short unfiltered multi way adapters, but not a long extension reel, or surge protected sockets.
There are never enough sockets in a room, especially for children, teenagers etc Smiley Wink
icclebug
Message 18 of 24
Oh yes, kids!
It’s just a 4 way 10 amp extension lead, 2m I think.
Message 19 of 24
@icclebug wrote:
Oh yes, kids!
Normally no problem with those.
icclebug
Message 20 of 24
