Moderator
Moderator
Message 11 of 20
Re: Save button unresponsive for updating device settings
Thanks @ZooBurner  and @AustinSpeedy  for the replies. I'll pass this on to the hub team and see if this helps them with this issue.
Cheers
John
Moderator
Moderator
Message 12 of 20
Hi @AustinSpeedy  Are you able to rename other devices no problems?
If it is just the camera1 and if so what sort is it and is camera2 the same model?
Cheers
John
crashcourse
Message 13 of 20
Hi @JohnC2
For me the save button simply wasn't operational and threw that javascript error regardless of what I tried to change. If memory serves I attempted to:
  • Save without making any changes
  • Save with one letter added/removed
  • Save after changing only the icon (not the name)
  • And tried these changes for multiple devices in my wireless devices list
The save button for the Wireless options (SSID/WPA2 edits) continued to work, so it wasn't every save button across the system. It was only an issue for me on the device editing pages. As I said, doing a factory reset fixed the issue, so my best guess was corruption during a recent firmware update.
I'm afraid this is all the info I can provide, but hope it helps.
Cheers
Moderator
Moderator
Message 14 of 20
Hi @crashcourse  thanks for coming back with that info and I'll pass it on to the hub team.
cheers
John
AustinSpeedy
Message 15 of 20
 Cameras are the same type exactly, but the issue is the same for other networked devices such as range extender
Moderator
Moderator
Message 16 of 20
Hi @AustinSpeedy  and @ZooBurner  The hub team was unable to recreate the issue. If this is still happening would you be able to post some screenshots? (block out any personal information).
John
ZooBurner
Message 17 of 20
Hi @JohnC
I'm not sure a screenshot would help, you can change say the wireless key in the box, but when you try and save it simply does not.
Neither do you get the warning box that alerts you that devices may loose connection etc.
AustinSpeedy
Message 18 of 20
As ZooBurner says, I can't see the point of screenshots, but I attach three in sequence - original settings, changed settings and result after saving - no change. Oddly enough I did successfuly change another device name and icon when I was doing the screenshots and this was one that would not save previouslyHubShot 1.jpgHubShot 2.jpgHubShot 3.jpg
ZooBurner
Message 19 of 20
@JohnC2
Just for information I had a firmware update to v0.15.00.06145-BT  on 24th September (though I understand this date is different for others)
All works as it should now, problem solved.
Z
Paul_31
Message 20 of 20
I'm experiencing this 'inability to save changes problem' as well (not for the first time: https://community.bt.com/t5/BT-Devices/Cannot-save-changes-in-Hub-Manager-SmartHub-2/m-p/1962485 ) and I'm now on the latest version of the the firmware ( v0.15.00.06145-BT, updated 28 Sept).
When I had the problem previously (running earlier firmware) a factory reset resolved the issue, but the problem has returned these last few days.
A partial workaround is that the MyBT App allows me to change the name of devices, but it doesn't offer the ability to change the icons associated with the devices.
I suspect another factory reset will once again fix the issue, but it looks to me that there is an underlying issue that is causing the problem.
For the time-being I'll resist the factory reset as it is only a minor problem. Everything else on my network works a charm.
Perhaps one of the mods with an eye on this thread can pass this on with all the other comments.
