Scorrybreck
Message 1 of 8
Screen resolution on BT Yahoo browser
My 'Windows Internet Explorer provided by Yahoo' (i.e. BT) browser has suddenly started displaying in a larger font as if the screen resolution has changed (images are also affected). No other application on my laptop is affected. I've tried changing the laptop screen resolution to correct this, however not only does it not fix the browser, it also upsets all the other apps on the laptop - so I don't think the screen resolution is really the problem. I have now returned it to the recommended native resolution and everything looks fine again, except for the browser! Changing the font size via the browser options also makes no difference. Has anyone else experienced this phenomenon?!!
Tags (3)
7 REPLIES 7
Paul-Joyce
Message 2 of 8
Re: Screen resolution on BT Yahoo browser
Hi
not sure if you have tried this but might be the problem have you checked the zoom level in the right hand corner of the window just above the system tray icons
Paul Joyce
groovesection
Message 3 of 8
If you are using Firefox or (Internet Explorer 😎 simply hit..
Ctrl and the + key (to increase font size)
Ctrl and - key (to decrease font size)
TaRkA
Message 4 of 8
Sometimes by accident you can also do this combo...
ctrl + mouse wheel
Ive done it plenty times, most of the new browsers support it too.
Scorrybreck
Message 5 of 8
Thanks for all the replies folks, and top marks to Paul - it was indeed merely the zoom level in the lower RH corner of the browser, which had mysteriously upped itself to 125%.
Please sir it wizzzny me (not consciously anyway!).
Cheers Paul!
Tags (2)
Paul-Joyce
Message 6 of 8
 Hi glad to hear you got the problem sorted, It Seems if you click that little star to the left I get a point for a correct answer - how sad that I would like you to do that for me
Paul Joyce
Scorrybreck
Message 7 of 8
I'm very happy to click your star Paul, you've earned it in my book!!
Done!
Message 8 of 8
Moved:
