snowmanrok
Message 1 of 2
Seagate Backup Plus Hub
Hi all - hoping someone can help, and also hoping I haven't bought the wrong thing!
I have purchased a Seagate Backup Plus Hub, and connected it by USB to my BT Hub Router.
It doesn't show up on my network - however, if I go into my router settings, I can see it connected to the USB - but can't seem to do anything else with it, other than change the icon.
I was hoping I could use this as a shared external drive (map it to a z drive or similar).
I have searched similar posts, and it seems people have had some success - but I am not sure how to do this, and haven't been able to follow the posts.
Would appreciate any help 🙂
Thanks all!
Tags (2)
1 REPLY 1
licquorice
Message 2 of 2
Re: Seagate Backup Plus Hub
If you are using W10, you need to enable SMB1 as it is disabled by default.
https://www.windowscentral.com/how-access-files-network-devices-using-smbv1-windows-10
Once enabled, you can map the drive to \\192.168.1.254\usb1
