tabirich
Message 1 of 4
Setting up Hub 5 as a wifi repeater
I've had a read of other posts and have disabled DHCP and given the Hub 5 a new IP address, yet i still have instability and a red flashing 'b'.
It does appear to work and no obvious conflictcs yet, but would like it to be a nice static blue light and no flashing 'b'.
Years ago I had a local IT company come set up a hub 3 just like this, as I have a Hub 6 in the house doing the master control, and the hub 3 and hub5 are daisy chained on the cat5 and are located in separate out buildings (so it helps understanding).
The hub 3 is in one outbuilding approx 5m from the house (where its connected via a cable). The hub 5 is on a 50m long cable to another outbuilding, and connected to the hub 3.
Am I missing something to have the Hub 5 set up the same as the hub 3?
Any help much appreciated, as I'm not overly good at this sort of thing but cant get anyone to come help due to covid unfortunately.
3 REPLIES 3
licquorice
Message 2 of 4
Re: Setting up Hub 5 as a wifi repeater
The hub doesn't have DSL input, so you will always have the flashing red b. Black gaffer tape will hide it. You will not get a blue light.
Les-Gibson
Recognised Expert
Message 3 of 4
You can't stop the flashing b, it's an alarm signal to  report that it has no WAN connection to the network. You may be able to remove the relay if you can locate it and have the skills but the easiest way around it is to stick a bit of insulation tape over it
                                                     If the Smart Hub 2 is BT's best hub yet then what does that say about its predecessors ?
tabirich
Message 4 of 4
Just wondering how the engineer managed to achieve this on the hub 3.
