Mac_Taylor
Message 1 of 2
Should my HH5 be making noises?
I was kneeling down beside my Home Hub 5 this morning and I heard noises coming from it, not loud noises, you have to be close to hear it (1/2 Meter), but I can hear noises that are simialr to a Spinning Hard disk - Now I know that the HH5 doesn't contain a Hard disk so that's ruled out - just wondering what the noise could be and if I should be concerned?
The Power supply is a good 1M away so it's not that.
Maybe some other HH5 users could see if their devices are making any wierd noises (for a device that I assumed would be silent running as there are no moving parts).
Thanks in Advance.
Mac.
Tags (3)
1 REPLY 1
Mac_Taylor
Message 2 of 2
Re: Should my HH5 be making noises?
Really should have checked the Boards before posting.. It seems that the noise is a common thing amognst HH5 users.
Mac.
