paulm1985
Message 1 of 9
Signal Issues
I recently got broadband installed and in every part of the house the connection is very good. However in a room about less than 10 metres from the hub i am having severe issues in getting a good wifi connection. There are brick walls in the way could this be an issue? Any other hints or suggestions? Would a booster do the job? Any help would be very much appreciated.
8 REPLIES 8
Keith_Beddoe
Message 2 of 9
Re: Signal Issues
@paulm1985
Which BT Home Hub are you using?
paulm1985
Message 3 of 9
Re: Signal Issues
Im not sure. I only got connected on 02/07/20 so whatever standard router that is issued at that time.
Tags (1)
Keith_Beddoe
Message 4 of 9
Re: Signal Issues
It should say on the back, which version it is, as there are a number of different ones.
paulm1985
Message 5 of 9
Re: Signal Issues
I'm not at home at the minute but from emails I can see its Smart Hub 2 - not sure if that is what you were after? Thanks.
Keith_Beddoe
Message 6 of 9
Re: Signal Issues
That would make sense. Were you also sent a black disc which links to the smart hub 2, or was that not an option  you selected when you placed your order?
paulm1985
Message 7 of 9
Re: Signal Issues
No there was no black disc. I dont remember it being an option or else I probably skipped on through that option.
Keith_Beddoe
Message 8 of 9
Re: Signal Issues
That would have cost more, as its part of the BT Complete Wifi Package.
As its only one area you need to cover, this would be the best option.
https://shop.bt.com/products/bt-mini-wi-fi-home-hotspot-600-kit-084288-BVFF.html
It generates a separate wireless network and has Ethernet ports as well.
paulm1985
Message 9 of 9
Re: Signal Issues
Thanks for your help I will look into that. Thanks.
