theFlash
Newbie
Message 1 of 5
Sipgate etc VOIP on residental BT Infinity - is it blocked or allowed?
Can't get a straight answer from BT customer service as they keep saying that VOPI is only on business lines - I suspect they are talking about their own VOIP service.
Can anyone asnwer me, before we switch to BT, can I use my own VOIP devices (e.g. for sigpate) on Infinity (residential)?
(I'd be using my own router too).
Many thanks,
Tags (3)
4 REPLIES 4
Message 2 of 5
Re: Sipgate etc VOIP on residental BT Infinity - is it blocked or allowed?
Welcome to this user forum. @theFlash
There is no restriction on VOIP. The home hub can have issues, but as you are using your own router there should not be any problems.
Make sure that you do not enable BT Web Protect or BT Parental Controls, as they can interfere with some services.
theFlash
Newbie
Message 3 of 5
Thanks.
Seems a no brainer considering it looks like calls to UK landlines are free, without that annoying hour limit, which we've just been stung by.
rogerx1
Message 4 of 5
Sipgate working fine here.
Distinguished Guru
Message 5 of 5
I have sipgate working fine on my broadband using a terminal adaptor.
(If I have helped you in any way please click the thumbs up. Thank You)
If I have solved your Issue please click the "Mark as accepted solution" button.
