Anthslife
Newbie
Message 2 of 6
Sky Q and Multiroom
Hi, I’m wondering if someone can help. I’ve just swapped my home hub 5b over to a 6b that I received as per of a trial last year and I can’t get my second multiroom box to connect as it’s saying that’s it’s not receiving an IP address. The main box is fine over Wi-fi and both worked fine on the 5b
Tags (2)
5 REPLIES 5
Anthslife
Newbie
Message 1 of 6
Sky Q multiroom
Wondering if anyone can help. I’ve just switched from my home hub 5b to my home hub 6b which I had as part of a trial but I’m unable to connect my Sky Q multiroom box as it’s saying it’s not receiving an IP address although the main box is working fine via Wi-fi. The only thing I’ve done is separate the wireless bands to separate 2.5g and 5g.
Message 3 of 6
Re: Sky Q and Multiroom
did you turn off smart setup?
Anthslife
Newbie
Message 4 of 6
Is that on the sky q or home hub?
Message 5 of 6
the hh6
Anthslife
Newbie
Message 6 of 6
I’ve disabled smart setup on the router and have had no luck. I’ve restarted router and all Sky boxes as well. I did also reset the wireless on the main box just in case but still the second box won’t connection and complains it’s not being allocated an IP address
