Message 2 of 8
Sky Q mini Box loses Wi-fi connection
I have just installed Sky Q all works fine except the mini box in the bedroom which is the furthest point from the router. Box connects but either loses signal completely or freezes and restarts. Tried calling Sky but they won’t do anything until wifi signal is confirmed as being stable how do I do this. Also would the latest hub cure the problem
7 REPLIES 7
Message 1 of 8
Sky Q mini box
I have installed Sky Q all works fine except the mini box in the bedroom which is the furthest point from the router, I have a booster in the hallway but it doesn’t make difference. Would the latest new hub cure the problem?
Message 3 of 8
Re: Sky Q mini Box loses Wi-fi connection
Hi @Kennyhammerfan. The Sky Q Mini box only connects to the Sky Q Main box and not your BT Router using it’s own WiFi system called the Sky Q Mesh. By default it uses the 5Ghz band on channel 36. It may help if you split the bands and move your BT Router 5Ghz band away from channel 36. If the Sky Q Mini is struggling to connect to the Sky Q Main box then you may need some Sky Q Boosters which will be installed by Sky installers. Try calling Sky again and you may get a customer advisor who knows that your BT Router has nothing to do with your problem. Simply tell them you are having problems with the Mini and nothing else.
http://bt.custhelp.com/app/answers/detail/a_id/56419/~/how-do-i-split-my-bt-hubs-ssid-%28wireless-ne...
http://bt.custhelp.com/app/answers/detail/a_id/14094/~/how-do-i-change-the-wi-fi-channel-on-my-bt-hu...
Message 4 of 8
Re: Sky Q mini box
unlikely
Message 5 of 8
Re: Sky Q mini box
@Kennyhammerfan Please don't post the same question on multiple boards it just causes total confusion.
Message 6 of 8
Thank you for your reply.
Message 7 of 8
Re: Sky Q mini box
Didnt know that I had
Expert
Message 8 of 8
Re: Sky Q mini box
Have you tried homeplugs ? They use your electric circuit in your house as a phone line
