ben9090
Message 1 of 4
Sky and Ring Devices wont re-connect
Last night I noticed that all my ring devices were offline (floodlight, doorbell and chime) After looking into it they all went offline at 620pm last night. I tried everything I could do to reconnect but nothing will work.
Later that night I realised the Sky Q boxes are also offline.
Ive tried again this morning and nothing has changed and they are still disconnected.
Iphones, Ipad, Laptop are all still connected and working fine so it just appears to be all sky and ring devices.
Ive tried switching everything off and on again! Does anyone have any idea why this has happened and what I can do to fix it? Everything has been running fine for months since I got the latest Hub.
3 REPLIES 3
Keith_Beddoe
Message 2 of 4
Re: Sky and Ring Devices wont re-connect
ben9090
Message 3 of 4
reset sorted it, thanks Keith
Keith_Beddoe
Message 4 of 4
That`s good. Sometimes the home hubs run out of internal connections, and the only way to reset them, is a factory reset. It should not be needed very often.
