Message 1 of 7
Sky constantly losing link with BT internet
I am constantly having to reset my Sky box and BT  Internet incuding resetting internet password on my Sky.
I have contacted Sky and they say it must be a BT fault but my BT Broadband is fine and I only have issues with it communicating with Sky.
Is it best to ditch Sky and use BT TV services so that any problems I only have one provider to sort it?
6 REPLIES 6
Message 2 of 7
Re: Sky constantly losing link with BT internet
try changing the Hub 5ghz wireless channel to anything other then 36 as that is used by SKY so say 44 or 48 and see if that helps
Message 3 of 7
Thanks - how do I change the Hub 5ghz wireless channel?
Message 4 of 7
got to hub manager 192.168.1.254 into address bar then go to advanced setting then wireless and change channel from smart to either 44/48 then save
Message 5 of 7
Hi
What address bar do I use to locate hub manager 192.168.1.254?
Message 6 of 7
the address bar at the top of a browser - google/edge/firefox
Message 7 of 7
Thank you
I have done what you suggested and it is now currently working. Hopefully it might stay connnected - we will see.
Thank you for your kind help
