andreaferns120472
Message 1 of 8
Sky q and PlayStation
I have recently had Sky Q installed.  However since this installation my sons PlayStation has become very slow when he is playing online.  The PlayStation is connected by a cable directly to BT Hub.  (BT have also recently sent me a new Hub)
I have spoken to Sky and they say I need to speak to BT as you are the broadband provider.  Sky suggested I ask you about a gaming profile for example the download and upload of online gaming?  I have no idea what this means.
They suggested changing configuration/profile of router to match online gaming.  I think the PlayStation needs a better upload speed.
However I do not want this to interfere with download speeds of Sky Movies and programs!
Since having Sky Q installed (we have 1 main sky q box and 2 mini boxes, with a Sky Booster) Not only has the PlayStation become very slow, the 2 Sky mini boxes kept loosing the connection.  So I had a Sky engineer visit the property again and they have hard wired the main sky q box and one of the mini boxes.  They could not hard wire the 2nd mini box as we needed a NETGEAR 5-Port Gigabit Ethernet Unmanaged Switch (GS105UK) which I now have and Sky are returning at the beginning of August to hardwire the 2ndSky Q mini Box.
However this does not solve the problem of PlayStation online gaming either being very slow and quite often not working at all.
We also have 3 BT Wholehome discs and BT Fibre!
This really should not be happening and Sky are trying to get me to change our broadband from BT to Sky!
However before I do this I would like to know if BT can offer any suggestions??
7 REPLIES 7
Moderator
Moderator
Message 2 of 8
Re: Sky q and PlayStation
Hi @andreaferns120472, thanks for posting, BT don't offer a broadband service specifically for gaming profile however I would recommend that you set up a port forwarding rule for the Playstation within he Hub manager as this might help.
What broadband speeds are you getting?
Community ModeratorNeilO
Show your appreciation!
Kudos”Kudos”
TimCurtis
Recognised Expert
Message 3 of 8
@andreaferns120472
Just out of curiousity do you have BT sport & a Youview box which is alongside the Q Box & through a switch?
Also what speeds do you get on your fibre broadband.
andreaferns120472
Message 4 of 8
Hi Tim
Yes we have BT Sport but not sure what you mean by a Youview box?  I have just ran a speed test on my PC and it came back download speed 8.16 and upload speed 2.83.  And then a ran another speed test using the BT app on my phone and that came back download 14 and upload 4.3.
andreaferns120472
Message 5 of 8
Hi Tim
andreaferns120472
Message 6 of 8
Hi.
How do I set up port forwarding rule for the Playstation within he Hub manager?
TimCurtis
Recognised Expert
Message 7 of 8
A Youview box is a BT supplied Freeview & Internet channel recorder and if watching BT Sport on it when you have a SKy Q box it can knock out the Sky Q minis.
But as you don't seem to have such a box then don't worry about my question.
andreaferns120472
Message 8 of 8
I had actually forgotten that I had already setup port forwarding for the Playstation a few months which was for the Smart Hub 1.  I have since received a new Smart Hub 2.  Do I need to do this again?
