Message 1 of 6
Sky q
Hi does anyone have problems with there sky q box disconnecting from bt halo quite regular .
5 REPLIES 5
Expert
Message 2 of 6
Re: Sky q
No, also Halo is the name of broadband with extra features.
What hub are you using ? also look at other posts that have suggestions, disable smart setup etc
Search is your friend :
https://community.bt.com/t5/Home-setup-Wi-Fi-network/Sky-Q-connection-to-smart-hub-2/m-p/2029276
https://community.bt.com/t5/BT-Fibre-broadband/BT-Broadband-amp-Sky-Q/m-p/2058131
Message 3 of 6
Re: Sky q
I am using the smart hub 2
Message 4 of 6
Re: Sky q
Turn off smart setup and change the 5g channel to ch48
Message 5 of 6
Re: Sky q
Ok thanks I will give that a go.
Message 6 of 6
Re: Sky q
It worked for me, and several others. Let me know how you get on
