Alex_B07
Message 11 of 15
Re: Slow speeds with HH5/Smart hub not working at all
Based on those stats, do you think I can rule out a problem with the line? Do you think it's more likely to be an issue with the hub?
Technonerd
Message 12 of 15
Nothing wrong with those stats, definitely a Hub issue.
imjolly
Message 13 of 15
when the hh6 was flashing orange did you try using the connection wizard to see if that could solve the internet connection problem?
Alex_B07
Message 14 of 15
Yep tried that, it eventually just told me to phone BT.
I called them up and had to sit throught the usual tests. "are you connected to the right hub?/have you turned it off for 30s"... eventually got it passed to the complex faults team who may try another replacement hub.
Technonerd
Message 15 of 15
Yeah, think you need a replacement Hub.
