Message 1 of 3
Slow upload on wifi, OK on cabled devices
Hi All
I have a HomeHub 5 connected by a cable to my home computer and wirelessly to a number of other devices. The dowload speeds are generally fine on all devices (circa 40MB/s) but the upload speeds are really poor on the wifi-connected devices (often 0.2MB/s or lower) whilst on the cable-connected home computer it seems fine (circa 9MB/s).
I've tried resetting the router -no change. This also happens when there is only one device connected wirelessly (my phone, doing a speedtest) so it isn't a contention issue that I can see.
Any ideas about wifi settings I could change or something?
2 REPLIES 2
Message 2 of 3
Re: Slow upload on wifi, OK on cabled devices
have you split the 2.4/5ghz networks?  have you tried selecting channels manually
Message 3 of 3
That seems to have worked - thanks. Seems the 2.4GHz channel works fine but the 5GHz channel has the low upload speeds. Phone must have been connecting to the latter.
