Message 1 of 14
Smart Hub 2 - 2.4GHz Radio Off, but Hub thinks it is on!
Hi All,
I have recently moved house and BT kindly gave me a Smart Hub 2 to use. It worked well for about 2 weeks, but now it's started playing up about once a day.
When the problem occurs, the Hub thinks that both radios are working and that all is well, but it is very much mistaken! The 5GHz radio is working, but the 2.4GHz Radio is off!
Here's what the Hub thinks
But here's what the printer knows:-
It's not just the printer, the issue affects all devices that connect exclusively over 2.4GHz.
I used WiFi Analyzer on my phone to see what was going on, and sure enough, the 2.4GHz radio is off.
My Smart Hub 2 is called 'BT Router'. You can see it operating over 5GHz but not on 2.4GHz
I've tried a reset and factory reset, but neither has worked.
This is a list of your BT Smart Hub settings and current statistics.
Product code:Smart Hub 2
Serial number:+091298+2014030724
Firmware version:v0.15.00.06145-BT
Firmware updated:Fri Jul 17 00:33:15 2020
Board version:R01
GUI version:1.56 15_02_2019
DSL uptime:0 days,05 Hours16 Mins20 Secs
Data rate:19.999 Mbps / 78.901 Mbps
Maximum data rate:20.759 Mbps / 80.692 Mbps
Noise margin:6.4 / 3.3
Line attenuation:9.9 / 16.7
Signal attenuation:9.9 / 20.0
VLAN id:101
Upstream error control:Off
Downstream error control:Off
Data sent / received:188.1 MB Uploaded / 6.0 GB Downloaded
Broadband username:bthomehub@btbroadband.com
BT Wi-fi:Activated
2.4 GHz wireless network name:BT Router
2.4 GHz wireless channel:Smart (Channel)
5 GHz wireless network name:BT Router
5 GHz wireless channel:Smart (Channel36)
Wireless security:WPA2 (Recommended)
Wireless mode:Mode 1
Firewall:On
MAC address:CC:D4:2E:AA:26:37
Software variant:-
Boot loader:0.1.7-BT (Thu Nov 30 09:45:22 2017)
Tags (3)
13 REPLIES 13
Message 2 of 14
Re: Smart Hub 2 - 2.4GHz Radio Off, but Hub thinks it is on!
Why is your printer transmitting a wifi SSID?
Message 3 of 14
Yes - HP-Print-F5-Officejet Pro 8620 on Channel 11.
Message 4 of 14
The question was why is it transmitting an SSID, it shouldn't be.
Message 5 of 14
Printers do transmit a wireless signal, that is to allow a direct computer to printer connection without involving a router.
Its called Wifi Direct, and can normally be turned off within the printer menu.
Message 6 of 14
Appreciate that but the OP is trying to connect to the printer via the hub as far as I'm aware, in which case it shouldn't be in ad hoc mode.
Message 7 of 14
Hi,
I used the printer as an example because it can only connect via 2.4GHz.
The problem isn't the printer. The problem is the router stopping 2.4GHz WiFi and disabling any devices that can only use 2.4GHz.
When I  cheked, the router 'thinks' that 2.4GHz is on, but WiFi analyser proves that it is off.
The only solution is to power cycle the Hub. It's currently using channel 1 for 2.4GHz.
Message 8 of 14
by power cycle I assume you mean just switching hub off/on  did you try a factory reset to see if that clears the problem - press the recessed button on back and hold 20/30 secs until lights flash  remember when hub reboots to turn off smart setup
Message 9 of 14
@rthdavid wrote:
Hi,
Odd example, its never going to connect to the hub in that mode.
Message 10 of 14
I hadn't noticed before, but the router channel info is quite interesting:-
There's no channel allocated to the 2.4GHz band!
Could the issue be with Smart channel ?
