Message 1 of 3
Smart Hub 2 Home hub manager revisited!
Please bear with me with yet another question regarding this apparatus. It appears that the change to DV in my area may be happening sooner than I expected (London area) and so you said why waste money buying a Smart Hub 2 from eBay etc just to try out the Home hub manager.
I have therefore managed to glean, courtesy of Google images the image below of the Advanced wireless set up page. Here it shows how I can change the SSID to my favoured one which all my peripheral should link to seamlessly and also change the password to the one indelibly printed in my brain. Also I see that there is a button for turning off the 5GHz band which is want I want to do as my system devices have always been OK on the 2.4Gz frequency.
2 REPLIES 2
Message 2 of 3
Re: Smart Hub 2 Home hub manager revisited!
Message 3 of 3
Thanks for your patience.
