Moderator
Moderator
Message 51 of 62
Re: Smart Hzub 2 WiFi Speed
Hi @Bernie747,
Welcome back to the Community.
Sorry to hear that you might be having the same issue.
Can you check within your hub manager what firmware version your hub is currently on?
Matt
Community ModeratorMatt
Show your appreciation!
Kudos”Kudos”
almondslice
Message 52 of 62
Firmware v0.12.02.11078-BT
New FTTP installed today,  bandwidth via ethernet is 300Mbps, over WiFi I'm lucky to get 50Mbps a via 5ghz and I'm literally in front of it .
Message 53 of 62
Hi @almondslice   50 mbps sounds like the maximum available on a 2.4 GHz band. How do you know that you are connected using the 5 GHz band?
almondslice
Message 54 of 62
I disabled the 2.4ghz option , Cheers.
Moderator
Moderator
Message 55 of 62
Hi @almondslice,
Glad to see that @VeteranISPUser has been able to help you get your issue sorted.
Firmware v0.12.02.11078 is not known to be affected by this issue.
Matt
Kudos”Kudos”
Johnmorris278
Message 56 of 62
My download speeds above (circa 120mbps) were when connected to 2.4ghz, according to the My Bt app.
Allegedly (but I only have this anecdotally) the current SmartHub2 soft/firm ware is capping the speed to a FTTC standard, hence the scheduling of the upgrade. Don’t know how long that will take to roll out.
Message 57 of 62
Hi @Johnmorris278   The My BT App v8.5.2 shows all devices connected using the 2.4 GHz band irrespective of actually being connected by Ethernet, 5 GHz or 2.4 GHz. Only the Smart Hub 2 Manager shows the correct connection.
Johnmorris278
Message 58 of 62
Oh!
maybe I’m too trusting of My BT app, how do I know the speeds it gives me are correct?
They’re always higher than the other options.
Message 59 of 62
Hi @Johnmorris278   I trust the speeds shown in the My BT App. They are spot on for me. It is only the v8.5.2 version that shows the wrong connection. We live in hope that the next update will fix the error 😀
almondslice
Message 60 of 62
Actually,  I'm finding the WiFi pretty disappointing on the hub , still no answer as to why the bandwidth via WiFi was poor .  I replaced it with my Google WiFi mesh and instantly noticed a significant improvement > 100Mbps on wireless.
