Message 1 of 4
Smart Hub 2 access USB files via android
Can anyone suggest a decent, and preferably free, android app that I can use to access files stored on a usb connected to the Hub.  I'd used ES File explorer years ago so something with a similar feel would be good as that was taken off the play store due to being a bit dodgy.
3 REPLIES 3
Message 2 of 4
Re: Smart Hub 2 access USB files via android
Solid Explorer
Message 3 of 4
Thanks, hoping to find something without ads as don't want to buy something as I'll rarely use it.
Message 4 of 4
Manged to find something called Cx file explorer, no ads and connected to the hub and USB no problem.
