spbond
Message 1 of 4
Smart Hub 2 and static routes
When will a BT hub provide the ability to add static routes so that I can support multiple subnets in my home network?
My QNAP and Synology NASs provide this functionality as to  many 3rd party hubs\routers.
Come on BT, you describe the Smart Hub 2 as your most intelligent router yet but it still lacks basic functionality.
3 REPLIES 3
licquorice
Message 2 of 4
Re: Smart Hub 2 and static routes
To how many of the millions of BT customers do you think such a facility would be of use? Probably about 0.001%. ISPs don't make fancy routers,they provide basic devices for the masses.
spbond
Message 3 of 4
Probably about the same number that use IPv6, a VPN through their router, DECT or DDNS.
cuteebony
Message 4 of 4
Hello,
A newbie here.  I know this is an old thread but I landed here after google searching for a way to add a static route on a BT smart hub 2. Were you able to resolve this issue in some other ways? Thank you.
