Message 1 of 12
Smart Hub 2 as a modem
Hello all,
I've recently purchased an Asus RT-AX58U router and I'm not great at this stuff but from what I understand, to make this work I have to set me Smart Hub 2 in modem mode? I've had a look into the hub manager and cant seem an option to do that.
Would someone please help me out?
11 REPLIES 11
Message 2 of 12
Re: Smart Hub 2 as a modem
there is no modem only mode in the BT Hub
Message 3 of 12
Send the Asus back and get the DSL version.
Message 4 of 12
Message 5 of 12
It will work but the Hub 2 will not be a modem, it will still be routing and natting, so you will have 2 routers and hence double NAT. That in itself is not necessarily a problem, but you need to be aware of how the configuration is operating.
Far simpler to just use a third party modem/router and not use a hub at all.
Message 6 of 12
Thank you for the response.
So from what I understand the asus router will be more like a bridge if I use in the current setup.
What DSL version did you mean and what'll that do?
Message 7 of 12
Asus devices come in RT versions which are pure routers and DSL versions which are combined modem/ routers which can be used as a direct replacement for a hub.
Message 8 of 12
There doesn't seem to be a DSL version of the 58U, you might want to consider the 68U https://www.asus.com/uk/Networking-IoT-Servers/Modem-Routers/All-series/DSLAC68U/
Message 9 of 12
Ok thank you and if not, I could but a separate modem to run along side the Asus AT router?
Message 10 of 12
please delete the amazon link as not permitted on forum
