Message 1 of 2
Smart Hub 2 at 50mpbs
my router is running at 50mpbs no matter what, on my phone, pc, all devices. My pc is running on a WIFI router extender and then plugged into that via ethernet cable and I was wondering if there was any way to speed up the download speeds?
1 REPLY 1
Message 2 of 2
Re: Smart Hub 2 at 50mpbs
Which BT broadband package are you on?
Post the connection stats from your router.
Have you tried connecting your pc direct to hub with ethernet cable
