SimonN
Message 1 of 3
Smart Hub 2 - change MTU value
Hi all. Is it possible?
cheers.
2 REPLIES 2
imjolly
Message 2 of 3
Re: Smart Hub 2 - change MTU value
no
SimonN
Message 3 of 3
Thanks.
would you happen to know what the default setting is? 1492 or 1500? Running a ping tests suggests it’s 1492 but would like to be sure. FTTH by the way.
