Message 1 of 4
Smart Hub 2 connection drop
I have had BT for years without any problem.
i have halo3 with the hybrid which has works fine for ages. Recently my hub has been flashing orange and the hybrid has jumped into life and connected.
if I restart the hub all returns to normal. If I don’t restart the hub it stays on the hybrid for ages before it reverts to the hub connection.
I contacted bt and they had a look and said I had Wi-Fi congestion. They sent me another Wi-Fi disc which I installed. I  was also told to do a factory reset if the hub which I did. They said there was nothing wrong with my line.
All was fine for a couple of weeks and then it started doing it again. I only have about 13 devices connected and it doesn’t seem to do it when there is high demand. It just seems to do it randomly.
i would love to fix this issue as it is driving me bonkers
3 REPLIES 3
Message 2 of 4
Re: Smart Hub 2 connection drop
It cannot possibly be a WiFi congestion problem as the only thing changing to resolve the problem is the broadband connection, ergo it is a line problem.
Message 3 of 4
I have 3 devices connected by Ethernet cable and the rest on Wi-Fi
Message 4 of 4
Thank you
