Message 1 of 11
Smart Hub 2 multicast
I've got a network streamer and I've got in connected via WiFi to my SH2. I'm having a few problems regarding using my streamer that the streamer manufacturer say I need to ensure my router is set to enable multicast. How do I find this?  Thanks
10 REPLIES 10
Message 2 of 11
Re: Smart Hub 2 multicast
The hub 2 supports multicast, there are no settings you can make.
Message 3 of 11
@witrochelli
What streamer are you using?
Not sure about the SH2 but previous Hubs/SmartHubs didn't support multicast over wifi.
Message 4 of 11
@TimCurtis  Missed the wifi bit, SH2 doesn't support multicast via wifi
Message 5 of 11
Thanks for your reply.
Its a Bluesound Powernode. It sounds great but I wanted to tweak the bass down a bit and to do that I use the BluOS app on my Android phone BUT I cant get into the audio settings. I've had a word though Bluesound and they tell me that this issue is most likely resolved by ensuring my router is multicast enabled.
Message 6 of 11
No multicast via WiFi - oh thanks. Not what I wanted to hear.
Message 7 of 11
If its working ok but just unable to access via app, its doesn't sound like its a multicast problem.
Message 8 of 11
No I was surprised as well but thats what they told me. Going to connect via cable and see if it works.
Message 9 of 11
Message 10 of 11
Yep, I'm very much doubting this is a router problem. Everything works fine except for accessing audio settings through the app. I switched Smart Setup off as advised - thanks. I've just unplugged everything, lugged the streamer over to the router and connected via cable.  Still doesn't work - this is app streamer issue I think.
