Message 1 of 17
Smart Hub 2, no guest network, help please
Hi, understand that the smart hub doesn't have an option for a guest network, which I really miss.
So I've been searching and there seems to be an idea that adding a complete wifi black disc, would allow you to setup a guest option.
I've installed the BT whole home WiFi app on my mobile. But it won't let me explore options without adding a disc first.
Interestingly it asks which disc pack you have, and the minimum is a 2 disc pack?  I only planned to buy one...
So any advice or experiences would be really appreciated
16 REPLIES 16
Message 2 of 17
Re: Smart Hub 2, no guest network, help please
You're mixing the discs up.
The black discs are Complete Wi-Fi Discs and are configured from the MY BT app and have no facility for a guest network.
The BT Wholehome Wi-Fi app is for the white discs.
Hence the Wholehome app is reporting that it can't find any discs because there are no compatible ones there to be found
Message 3 of 17
Ok thanks,
Maybe another option would be to buy a wired wireless access point, with a guest network facility?
Message 4 of 17
Why is a guest network so important? Don't you trust your guests?
Message 5 of 17
You would not get total isolation on a wireless access point with guest isolation. Guests would still be able to access your LAN via the home hub.
Some modem/router combinations with a guest network, do provide isolation within NAT, and guests are assigned a separate IP subnet.  Its similar to the free Wi-Fi provided by some retailers, where their own internal network is isolated from the free guest network.
To achieve full isolation on a home network, is quite involved. But it can be done using a managed network switch which supports VLANs.
If you just want to provide a separate wireless access point for guests, then that is easy, just assign a different SSID and password, but bear in mind  they can access any unprotected network shares.
Message 6 of 17
Many thanks
Message 7 of 17
Here's a scenario, bloke arrives to fit new dishwasher. He wants to use my wifi on his phone (the mobile coverage in my home is very poor) so I give him my wifi password.
Later, parked up outside my house, he uses my wifi to download the worst kind of illegal stuff.
Guess who gets their door knocked at 5AM and all their kit confiscated.
That's why you need a guest wi-fi network and BT not having it on their most numerous router is **bleep**.
Message 8 of 17
@gavin7
I can't understand why you would give your wireless password to a complete stranger who is fixing an appliance knowing that will give access to your complete network.  And then having made that mistake why you then didn't immediately change the wireless password to avoid any problems you highlight
Message 9 of 17
Any sensible person would temporarily change the password first and then revert.
Yeah, like thousands of tradesmen do that
If you say so
Oh, and by the way, they would still come knocking on your door guest wifi or main wifi, its still your responsibility.
Message 10 of 17
Along with above information and folly of allowing an unknow person to use your network, as has been pointed out, even if you have a guest network, in the event of the scenario that you have posted, the authorities would still come to your home. The guest network is still your responsibility because it is emanating from your broadband.
If it was that simple to avoid detection for illegal activity do you not think that any person wishing to do illegal stuff  would just need to set up a guest network in their own property and surf away rather than using a VPN, TOR browser or the plethora of other ways they use to avoid detection.
