gerry_4
Message 1 of 32
Smart Hub 5 Firmware
How do know if your Hub has the latest firmware, is it automatically updated? I can't find an option to see if the Hub has the latest firmware or update.
Ta
31 REPLIES 31
smf22
Recognised Expert
Message 2 of 32
Re: Smart Hub 5 Firmware
There used to be a page listing the firmware versions, but I can't find the link right now. These are the firmware versions I know of for the HH5A and HH5B
Home Hub 5A
Software version 4.7.5.1.83.8.57.1.3
Software version 4.7.5.1.83.8.173.1.6
Software version 4.7.5.1.83.8.204.1.11
Software version 4.7.5.1.83.8.222.1.1
Home Hub 5B
v0.07.01.0235-BT
v0.07.03.0814-BT
v0.07.05.0A13-BT
v0.07.06.09028-BT
It's largely irrelevant though as you have no option to manually change the firmware version or to request an update. BT will do this automatically.
Regards
gerry_4
Message 3 of 32
Thanks for that, my version is 4.7.5.1.83.8.204.1.11 which was updated in August 2015. I thought in 1 1/2 years there would of been a update. Mine is the HH5A. Is the "Software version 4.7.5.1.83.8.222.1.1" the latest version then?
smf22
Recognised Expert
Message 4 of 32
The 4.7.5.1.83.8.222.1.1 firmware is the latest I'm aware of, and going by the date mine was updated, was released in early 2016.
Whilst you can't initiate an update you may well see one in the near future as BT have stated they'll be enabling IPv6 on the Home Hub 5 in early 2017.
Regards
gerry_4
Message 5 of 32
I was enquiring because of connection issues and hoped that an upgrade would fix it
Thanks for the info
Distinguished Guru
Message 6 of 32
My hub's been stuck on 4.7.5.1.83.8.204.1.11 ever since I bought it (second-hand).  I don't have any problems with it, so i suspect your problems are elsewhere.
Message 7 of 32
@smf22
the hub 5b rollout started before Christmas and  hubs with it are now on IPV6
MorgaineD
Expert
Message 8 of 32
@john46: Excellent news, thanks! 🙂
My HH5B hasn't been updated yet, not since 29 Oct 2016, but after your info I'll be monitoring it closely. 🙂
Tags (1)
Message 9 of 32
firmware version v0.07.06.09028-BT
MorgaineD
Expert
Message 10 of 32
@john46: Are you sure? That is my firmware revision already.
Pasting directly from the HH5B's Heldesk window:
    v0.07.06.09028-BT (Type B) Last updated 29/10/2016
And Advanced Settings->Broadband->IPv6 Status says:
    IPv6 will be disabled on your BT Home Hub and BT Broadband Network until supported by future services.
Also, Advanced Settings->Home Network->IPv6 Configuration says:
    IPv6 Configuration is not currently enabled as your BT Home Hub and/or BT Broadband Network are not enabled for IPv6.
