furse
Message 1 of 13
Smart Hub 6 Ethernet
I am trying to connect an access point to increase my wifi in the other end of my house. I have a Cat 5 running from the Ethernet port of the hub to a Tenda i12 access point. I have set the IP address and IPv4, but in my BT Hub Manager it does not show any ethernet connections, only Wireless ones.
I have moved the access point to next to the hub to eliminate the cat5 cable and its still the same
I have Factory reset the hub, still nothing
12 REPLIES 12
albertj
Recognised Expert
Message 2 of 13
Re: Smart Hub 6 Ethernet
Hi @furse
Welcome to the Community.
I am slightly confused by your problem, is your access point not showing in Hub Manager?
If I have helped you in anyway please press the Kudo button (thumbs up)
If I have resolved your post please click 'Mark as Accepted Solution'
furse
Message 3 of 13
No it is not showing in the hub manager under devices, no devices are shown in any Ethernet ports, only wireless devices
The access point is showing as a option if I search available networks, so I think that is working ok, but I can’t access the utility to add security etc
Anonymous
Not applicable
Message 4 of 13
Remember you are limited to 100m for a cat 5 cable
You didn't say if you're running the cable to a LAN port (not the WAN) on the Tenda i12.
If your cable is less than 100m and is plugged in to a LAN port then try unplugging the cable from the Tenda i12 and plug it into a laptop instead, set the ethernet adapter to acquire an IP address automatically and then try opening a web page.
If your laptop won't connect to the web then your etherenet cable may be faulty or incorrectly wired.
furse
Message 5 of 13
Cat5 run is no more than 50m, it has tested out ok, but it doesn’t work if I plug the Tenda straight into the LAN port on the back of the hub (so no cat5 run)
will try the other things you mention anyway, thanks
Anonymous
Not applicable
Message 6 of 13
That makes me wonder if the IP address of the Tenda is in the correct subnet and not conflicting with the HH6 which by default is 192.168.1.254.
I suggest setting the Tenda to 192.168.1.1 static
licquorice
Message 7 of 13
Rubbish deleted
Anonymous
Not applicable
Message 8 of 13
@licquorice
I get your point but have you not posted this in the wrong place?
licquorice
Message 9 of 13
Anonymous
Not applicable
Message 10 of 13
@licquorice
Look back at the OP
