lhrwilson
Message 1 of 4
Smart Hub 6 Firmware
Can anyone help?
I have had the BT Smart Hub since august, however it is yet to upgrade its firmware, reporting it was last updated in june. The current firmware version on the hub is SG4B100021F4
Is there any way to force it to update? Or Manually do the update?
Any Help Would Be great
3 REPLIES 3
Message 2 of 4
Re: Smart Hub 6 Firmware
Not possible.
Judging by the posts on this forum, be careful what you wish for.
lhrwilson
Message 3 of 4
Thank You @licquorice
I may be better just leaving it then
Message 4 of 4
Nothing you can do. If it is connected, it will get updated as and when BT see fit.
