therockett
Newbie
Message 1 of 8
Smart Hub 6 rebooting, not able to log into admin page
Have an issue with the Smart Hub 6 in that it seems to keep rebooting, we get connection for about 3 to 4 minutes then it drops out and cycles through the lights. We have tried to access the admin web portal but keep getting no connection message. We have also tried factory reset which seems to have no effect (light does not go out). This is the second time in a week and BT are being their usual useless selves by not sending an engineer until Wednesday.
7 REPLIES 7
Message 2 of 8
Re: Smart Hub 6 rebooting, not able to log into admin page
Welcome to this user forum.
It does sound like a faulty HH6, as there appear to be a number with hardware failures.
Its a good idea to check your phone line first.
Is there any noise on your phone calls? Dial 17070 and select option 2, there should be no noise between the announcements.
therockett
Newbie
Message 3 of 8
Hi and thank you.
Completed the quiet line test and no audible noise, looking at getting an Asus DSL-AC68U to replace the HH6
thomasmulhall
Message 4 of 8
I'm having the same problem.
Message 5 of 8
therockett
Newbie
Message 6 of 8
Bought the Asus as mentioned above and now fully up and running again so confirmed as a HH6 failure
impster
Message 7 of 8
Exactly the same problem here. Using a hh5 for now which is fine, so obviously a major hh6 issue.
thomasmulhall
Message 8 of 8
I got mine replaced, will take 2 days for the replacement to come.
In the meantime i am using an apple airport express and i can now connect to the internet.
I think this may be a bug in the bt smart hub. must have been something to do with that extra second added before new years.
