Rocky77
Message 1 of 3
Smart Hub 6 won't connect to wifi
i cant connect to WIFI on my smart HUB is it a fault or a fake hub,
bought on ebay for less than half the price of BT.
HELP ..
PLEASE
2 REPLIES 2
gg30340
Message 2 of 3
Re: Smart Hub 6 won't connect to wifi
Without seeing or testing the hub it is impossible to say if it is faulty or a fake.
Try a factory reset of the Smarthub by pressing a pin into the recess button on the rear for about 20 seconds.
After you have done that make sure that you are using the wireless passkey/password and not the Admin password to connect to the Smarthub.
imjolly
Message 3 of 3
first thing after factory reset is turn off smart setup
