Expert
Message 1 of 1
Smart Hub 6A port fault
Hub connected to YouView+ box and all I can get is radio.
Reset YouView & it stops at 'Loading'
The BB light on the YouView is out.
Check the Hub on PC and YouView is not showing.
Eventually I remove cable from port on Hub, put it back - no change.
Move cable to next port and all is well.
Solved, sort of.
If the ethernet port has failed how can I still get radio but not TV.
I do not use a 'pass thro'
Anyone with ideas
David
