Uppy
Message 21 of 23
Re: Smart Hub (HH6) with Sonos
I replaced the HH6 with a TP Link Archer VR600. Been working trouble free for over a month now. HH6 sold on eBay
rich833
Newbie
Message 22 of 23
Thanks!
XAPPO
Message 23 of 23
I do notice that you have a static IP setup for the same range as those allocated by DHCP. Your DHCP server should be setup to have its own range.192.168.1.188 - Some DHCP servers check an address is free but some don't ..or the static may have arrived after the lease was granted.
Also check you don't have two paths back onto your wired network e.g. two cables or cable plus WiFi. This can create loops flooding the network. Your switch would need to support STP to avoid this ( spanning tree protocol)
