Newbie
Message 1 of 1
Smart Hub Technical Log& Local Host
What is the device called localhost? Cannot find a clear description of what  it is and what it does. Possibly the same thing, but looked into the technical log and can see another device/MAC I do not recognise trying access the hub as if it were polling it every second or so. Grateful for some help here🤔
