Message 1 of 6
Smart Hub as modem only
I am sure if it possible the folks here will know. Can the Smart Hub be configured as a modem only, Thanking you in advance Sue
5 REPLIES 5
Recognised Expert
Message 2 of 6
Re: Smart Hub as modem only
Afraid not. It only runs as a combined modem/router.
Regards
Message 3 of 6
Oh dear, thank you for the very quick reply. When setting up a third party modem router, how does this affect your DLM, Thanking you in advance Sue
Message 4 of 6
you should have no problems providing you do not make multiple restarts of your new router
Recognised Expert
Message 5 of 6
It shouldn't affect it at all. Any reputable modem / router will be as good, and probably better, than the 'Smart Hub'.
DLM is affected by line quality, and with the number of resets etc., that the Hub 6 needs to resolve the many issues it has, l'm sure you'll see better performance with any third party router.
I changed from the Smart Hub to a third party router and haven't had a line drop in over 70 days
Regards
Message 6 of 6
Thank you ever so much good people.
