Message 1 of 2
Smart Hub or TP-Link for FTTP?
I'm waiting for the internal installation part to complete our FTTP order, as well as for the delivery of the BT Smart Hub.
From what I've read, the BT Smart Hub is a bit temperamental. So now I'm tempted to order a 3rd party modem router, specifically TP-Link. I'm considering the following 2 models:
TP-Link AC1900 Wireless Dual Band
TP-Link AC2600 Dual Band Wireless
Are they suitable as a BT Smart Hub replacement, and which would be the better one if yes?
Thanks in advance.
1 REPLY 1
Message 2 of 2
Re: Smart Hub or TP-Link for FTTP?
You will need to remove the links. It's against forum rules to link to e-commerce sites.
Just post the names of the routers.
Either of the routers would do the job.
