Newbie
Message 1 of 8
Smart Hub
Hi, About to be connected to Infinity 1 next week. Wondered if anyone out there knows if the Smart Hub is better than the Linksys EA6900 smart router. I have been using the Linksys EA6900 1900 AC router for about two years and it has performed amazingly well on Sky broadband
Tags (1)
7 REPLIES 7
Message 2 of 8
Re: Smart Hub
Welcome to this user forum.
That is just a wireless router, not a VDSL modem/router, so it will not work unless you have a white Openreach modem as well.
If you were on Sky Fibre, with an Openreach modem, then continue to use your wireless router. You will have to change the PPP login details.
Newbie
Message 3 of 8
Re: Smart Hub
Hi Keith, Thanks for your post. I should have said I am using it currently with Draytek VIGOR 120 ADSL2/2+ Modem.
Newbie
Message 4 of 8
Re: Smart Hub
I guess the purpose of my post to gauge whether the new Smart Hub is better than my current modem and router setup.
Message 5 of 8
Re: Smart Hub
you need a vdsl modem not adsl for infinity
Message 6 of 8
Re: Smart Hub
@STEP325 as @imjolly has said, you cannot use that modem.
If you can get hold of a VDSL modem, then you can use your router. Its possibly better than the smart hub, but you will have to decide that yourself if you decide to buy a modem.
Try the smart hub first, before you spend any more money on a modem.
Newbie
Message 7 of 8
Re: Smart Hub
Thanks for your posts. Of course. This will be my first move from std broadband to fibre. I will give the Smart Hub a go next week just slightly apprehensive as when I have moved providers before the ISP provided kit has been poor in terms of WiFi performance and coverage to the point I have always have bought my own kit.
Message 8 of 8
Re: Smart Hub
@STEP325
When you get hh6 turn off smart setup and then split the 2.4/5ghz networks and select channels manually then see how it goes
