Message 1 of 2
Smart Hub
Do I need to keep my broadband smart hub powerd up all the time 24/7.
1 REPLY 1
Message 2 of 2
Re: Smart Hub
If you are on Hybrid Fibre (FTTC) then it's advised to keep the router (smart hub) switch on and connected 24/7. Regularly switching it off and on again can reduce your speeds as the equipment that tries to keep your connection stable thinks there is a problem with stability of the connection and therefore reduces your speed.
Also if on Digital Voice your phone service needs the smart hub to be constantly on and connected too
