Saffie24
Message 1 of 2
Smart TV drops Wi-Fi when BT box turns on
Hi there.
Is it normal that my smart tv will disconnect from Wi-Fi when I turn ON my BT TV box? When the box is off the WiFi works fine. But once I turn BT on none of my smart tv features work as it says it is disconnected from the internet? Even though my BT box had the Ethernet cable attached.
1 REPLY 1
Moderator
Moderator
Message 2 of 2
Re: Smart TV drops Wi-Fi when BT box turns on
@Saffie24 I've seen similar reports about this before. What router are you using and do you have an ethernet switch connected to your home network?
