Message 1 of 2
Smart hub 2 - 2.4gz needed for smart lights
Hey, I've recently set up my smart hub 2 after putting it off for ages and now my smart lights won't work as it needs to be on the 2.4gz network but I can't seem to separate 5gz & 2.4gz.
How on earth do I go about getting these to work with this new smart hub 2?
Thanks.
1 REPLY 1
Message 2 of 2
Re: Smart hub 2 - 2.4gz needed for smart lights
As has been posted numerous times on the forum. Turn of the 5ghz network, then connect your 2.4ghz devices and once connected then re-enable the5ghz network
