Message 1 of 5
Smart hub 2 alternative
Anyone know of a g.fast modem/router to replace the smart hub 2?.
Matt
4 REPLIES 4
Sage
Message 2 of 5
Re: Smart hub 2 alternative
TP-Link AC2800 Wireless Dual Band Gigabit VoIP G.fast Modem Router
Message 3 of 5
Where do you buy one of those, There is one listed on Amazon but it does not support G.Fast
Expert
Message 4 of 5
Hi,
Yes, I had a look a this product and can find no mention of it supporting G.Fast either. Looking in Amazon questions for the device, most people state it is not companies and has been listed wrong on Amazon. Even though it does say G.INP support in the datasheet.
I can’t see much for third party routers supporting G.Fast.
If you got lucky and your install included a Openreach Modem then you can just plug any router into this, provided it has a WAN Port.
If you don’t have this, you can look at this guide, made by someone also on G.Fast, on turning the Smart Hub into a modem so you can plug your router into this.
Hope that helps.
If I have helped you in anyway please press the Kudo button (thumbs up)
If I have resolved your post please click 'Mark as Accepted Solution'
Message 5 of 5
