Newbie
Message 1 of 1
Smart hub 2 and Tp links.
I am hoping someone can help. I had a hub 6 which gave up after a storm when the socket broke as the result of a surge. They have sent me a smart hub 2 and after almost three weeks of faffing around my broadband band is up and running. However. We have previously run the tv's using tp links as apposed to have ethernet cables trailing around the house. Now it appears that the smart hub 2 is not compatible with tp links, please correct me if I am wrong, and if it is I cannot get it to connect! Is there any way around this? We are only guaranteed 1mbps but normally get between 5&8. The tp links worked perfectly with our set up and I cannot figure out an alternative option.
