IanGregory
Message 11 of 12
Re: Smart hub 2 issue
I have had similar issues with the dual band signals. Even on new equipment (iPhone XR).
With errors such as “incorrect password” or “unable to connect”
It works reliably when I switch off 5ghz band and becomes unreliable when I switch it on again.
You cannot split the SSID’s on the smart hub 2 which would probably help if you could.
Keith_Beddoe
Message 12 of 12
deleted by poster
