mattdudley79
Message 1 of 12
Smart hub 2 issue
Got the new smart hub 2 but both smart tvs in the house are unable to connect to the internet
11 REPLIES 11
Keith_Beddoe
Message 2 of 12
Re: Smart hub 2 issue
Welcome to this user forum.
Try turning Smart Setup off.
http://bt.custhelp.com/app/answers/detail/a_id/44328/~/switching-smart-setup-on-and-off-on-the-bt-ho...
Did you have another home hub before this one, and did that work?
mattdudley79
Message 3 of 12
Smart setup already turned off,had the smart hub 1 before and tvs had no problem connecting to it
Keith_Beddoe
Message 4 of 12
Why did you change it, as the Smart Hub 2 offers no advantage unless you plan to rent the extra disks from BT ?
It also has a major disadvantage, as you cannot separate the SSIDs, which causes problems with some wireless devices, which is probably what you are trying to do.
Have you tried a direct Ethernet connection, does that work?
Also try disabling the 5GHz wireless on the home hub, and see if that helps.
mattdudley79
Message 5 of 12
It works when i turn off 5ghz but that defeats the point of having a dual band router.
Keith_Beddoe
Message 6 of 12
If you connect it to 2.4GHz, then enable the 5GHz, doe it remain connected to 2.4GHz, as that is one solution which was posted on another thread, where smart device could not connect.
The problem is that you cannot rename the two bands like you could on the old hub, and this upsets devices that can connect to both bands if they have the same SSID.
If you still cannot resolve it, then I suggest that you just use your old hub instead.
mattdudley79
Message 7 of 12
It only remains connected untill i turn tv off,then i have to connect again,didnt really want to go back to my smart hub 1 as i could never get the xbox to work wired.mayby i should in invest in a 3rd party router
Keith_Beddoe
Message 8 of 12
I assume you did not upgrade to ultrafast, and needed the smart hub 2?
The nearest third party router which works will all BT delivered services, and fully implements UPnP (Xbox etc)  Would be the  TP-Link AC1200 Wireless Dual Band VDSL/ADSL.
A single band one would be about £40.
mattdudley79
Message 9 of 12
Think im on infinity 2 i get 68mps someone has recommended the tp link ac2800 would that be ok
Keith_Beddoe
Message 10 of 12
Yes, its just more expensive, it depends on how much you want to pay.
https://www.tp-link.com/uk/products/details/cat-15_Archer-VR2800.html#specifications
Emulator https://emulator.tp-link.com/VR2800V1_Emulator_2017042605/index.htm
