Message 1 of 3
Smart hub 2
Hello   I have carried out a wifi analyser test and note that my sh2 is operating 5ghz on channel36 as is my SKY Q mesh and other nearby networks.  If I manually change frequency in router of 5ghz band I believe this switches off the smart bit of the router?  What are the repricusions of this please?
2 REPLIES 2
Message 2 of 3
Re: Smart hub 2
The so called smart wireless functionality allegedly selects the optimum channels. It rarely does and manual selection of channel is often better
Message 3 of 3
Re: Smart hub 2
Brilliant thank you.   I was hoping for that answer!!
