DaddyDee
Newbie
Message 1 of 4
Smart hub and openreach fiber network help
I've just moved to a brand new home with an openreach box under the stairs. I'm told it's a ftth network.
I've just received my smart hub in the post. Do I connect the grey cable from the openreach box to the WLAN port on the smart hub? It won't fit into the broadband port.
(I'm new to all this. I've lived on a farm for years with no intetnet)
3 REPLIES 3
Message 2 of 4
Re: Smart hub and openreach fiber network help
I assume you mean the WAN port? The answer is yes in that case.
Message 3 of 4
Yes, to the red WAN port.
DaddyDee
Newbie
Message 4 of 4
Yes. I meant that. Thank you guys!
